star96
Apr 06, 2015Novice
Firmware for Bigpond Aircard 790S
I would like to download firmware version NTG9X35C_01.03.28.05 (Build Date 2014/10/16) for my new 790S aircard (ISP is Bigpond). That is the version it currently runs. USB tethering with the IP Passt...
apac_se
May 26, 2015Apprentice
Hi Star96,
Try placing the AC790S into IP Passthrough Mode via Settings - Router. Please note that enabling IP Passthrough will disable WiFi capabilities and the only way you can access the AC790S in this mode is via USB cable. Enabling IP Passthrough disables any NAT's and should behave like a USB only modem.
