Feeldennis
Mar 20, 2019Tutor
Firmware for Nighthawk M1 Failure to update (NTG9X50C- 12.02.06.01)
Hello Community,
I got a branded ATT Night hawk M1 portable router, I unlocked with the unlock codes.
Right now it is working fine.
But, the firmware update never works.
Since I am ...
Blanca_O
Apr 10, 2019NETGEAR Employee Retired
Hi Feeldennis,
Just to verify, are you using an AT&T Sim when running the update?
Though the device is unlocked, you cannot change the AT&T logo.
Blanca
Community Team
- FeeldennisAug 02, 2019Tutor
Hi,
I am not using an AT&T sim card while trying to up date.
Thanks
