HannaS123
May 23, 2019Aspirant
Firmware for Nighthawk M2 MR2100
Hi All, Does your MR2100 have IP passthrough option? Settings> Setup> Mobile Router setup. If so, who is your SIM provider and what is the latest version of firmware? Settings> Administration> Firm...
Blanca_O
Jun 04, 2019NETGEAR Employee Retired
Hi HannaS123
May we please know the exact model of your MR2100? What is the firmware version?
Blanca
Community Team
HannaS123
Jun 05, 2019Aspirant
exact model of your MR2100? where can I find this info?
- Blanca_OJun 27, 2019NETGEAR Employee Retired
Hi, All,
Please check your Nighthawk M2 for firmware update. Kindly upgrade the firmware to 10.13.05.00 if it is a Telstra variant. Please let us know of the result.
Blanca
Community Team- DrEvilJimJun 27, 2019Aspirant
hi Netgear staff,
please advise if the new firmware upgrade for the M2 provides port forwarding function
10.13.05.00
regards, Jim
- ArodiDJun 28, 2019NETGEAR Expert
Hi DrEvilJim ,
The latest FW 10.13.05.00 does not have port forwarding feature enabled. Port Forwarding will be switched on in a future MR. Unfortunately, there is no ETA for the next MR which is not what you want to hear I am sure. I will update the post once a newer MR becomes available.
Arodi
Community Team
- HannaS123Jun 27, 2019Aspirant
I reported two problems with Nighthawk M2 Model MR2100:
1. Backup is not available in the settings
2. There is no IP PASSTHROUGH mode available.
Firmware was updated yesterday. The result:
On the dashboard a link appeared to: “Update Available – see Settings”. When I press it, it brings Firmware update screen with original firmware version, NTGX24_10.09.01.00, but this time update button is disabled.
No backup or passthrough available.
Very frustrating- ArodiDJun 28, 2019NETGEAR Expert
Hi HannaS123 ,
Can you please try the below for me?
1. On the TouchUI tap Settings>Software>Check For Updates - See if the update can be completed. If not try option 2.
2. Factory reset MR2100 by tapping on Settings>More>Factory reset. After factory reset has completed, step through the on-screen setup and retry option 1.
If you are still having issues then please PM me and I will help you resolve it. I can confirm that IP Passthrough is working on latest firmware 10.13.05.00.
Arodi
Community Team
