HannaS123
May 23, 2019Aspirant
Firmware for Nighthawk M2 MR2100
Hi All, Does your MR2100 have IP passthrough option? Settings> Setup> Mobile Router setup. If so, who is your SIM provider and what is the latest version of firmware? Settings> Administration> Firm...
HannaS123
Jun 05, 2019Aspirant
exact model of your MR2100? where can I find this info?
Blanca_O
Jun 27, 2019NETGEAR Employee Retired
Hi, All,
Please check your Nighthawk M2 for firmware update. Kindly upgrade the firmware to 10.13.05.00 if it is a Telstra variant. Please let us know of the result.
Blanca
Community Team
- DrEvilJimJun 27, 2019Aspirant
hi Netgear staff,
please advise if the new firmware upgrade for the M2 provides port forwarding function
10.13.05.00
regards, Jim
- ArodiDJun 28, 2019NETGEAR Expert
Hi DrEvilJim ,
The latest FW 10.13.05.00 does not have port forwarding feature enabled. Port Forwarding will be switched on in a future MR. Unfortunately, there is no ETA for the next MR which is not what you want to hear I am sure. I will update the post once a newer MR becomes available.
Arodi
Community Team
- HannaS123Jun 27, 2019Aspirant
I reported two problems with Nighthawk M2 Model MR2100:
1. Backup is not available in the settings
2. There is no IP PASSTHROUGH mode available.
Firmware was updated yesterday. The result:
On the dashboard a link appeared to: “Update Available – see Settings”. When I press it, it brings Firmware update screen with original firmware version, NTGX24_10.09.01.00, but this time update button is disabled.
No backup or passthrough available.
Very frustrating- ArodiDJun 28, 2019NETGEAR Expert
Hi HannaS123 ,
Can you please try the below for me?
1. On the TouchUI tap Settings>Software>Check For Updates - See if the update can be completed. If not try option 2.
2. Factory reset MR2100 by tapping on Settings>More>Factory reset. After factory reset has completed, step through the on-screen setup and retry option 1.
If you are still having issues then please PM me and I will help you resolve it. I can confirm that IP Passthrough is working on latest firmware 10.13.05.00.
Arodi
Community Team
- HannaS123Jun 28, 2019Aspirant
Hi Arodi, thanks for your advice.
I followed your step 1 and indeed new firmware NTGX24_10.13.05.00 has been installed.
Settings>Setup>mobile router setup: No IP pass through;
SETTINGS > Administration > no Backup available
Regards
Hanna
