rychro
Jun 01, 2022Aspirant
Firmware Nighthakt M2
I have a bricked M2, it does not start. Please send me the current firmware. Best regards Roman
Blanca_O
Jun 15, 2022NETGEAR Employee Retired
Hi rychro,
May we please know the device SKU (e.g. MR2100-1TLAUS)? This can be checked on the box of the product or on the barcode label
Have you tried factory resetting the device? Please remove the SIM card and hold down the reset button until you see a change in the LED.
Blanca
Community Team
- rychroJun 15, 2022Aspirant
Dear Bianca
The SKU is: MR2100-100EUS
I've tried a factory reset several times. But this could not solve the problem.
With no SIM installed.
Best regards
Roman
- Blanca_OJun 21, 2022NETGEAR Employee Retired
- Mr-MMRSep 24, 2022Aspirant
Hi Blanca_O ,
can you send me the file as well? I do have a MR2100 which stucks in boot with the first of the four dots. Resets are not working with or without SIM, with or without battery etc.
Im am able to plug in to power supply holding down reset until it sas "downloading firmware" and then it stucks again. In booth the display is slightly flashing white every few seconds. So I'd like to do a forced firmware update....
P.S. Also SKU: MR2100-100EUS
- TransfluxorOct 03, 2022Apprentice
- Blanca_OOct 03, 2022NETGEAR Employee Retired
MR2100-1TLAUS is an ISP / Telstra SKU. There is no option to manually update the firmware as it is locked by the Internet Provider. All upgrades are provided over-the-air.
Kindly describe the issue you are facing with your device. Can you please let us know what troubleshooting you've tried?
Blanca
Community Team- TransfluxorOct 04, 2022ApprenticeThe router was bought on Aliexpress. The router does not boot (both with and without sim, with and without battery, tried with a third-party charger QC3.0 Xiaomi HA612). Two black dots on the screen and the power indicator blinks red. It doesn't show up in device manager. But if I hold down the reset at power on, the Netgear QDloader port appears. The Sierra / Netgear flasher may well flash, I only need the firmware to try, even the oldest one, and then update over the air.
