rychro
Jun 01, 2022Aspirant
Firmware Nighthakt M2
I have a bricked M2, it does not start. Please send me the current firmware. Best regards Roman
Transfluxor
Oct 03, 2022Apprentice
Blanca_O
Oct 03, 2022NETGEAR Employee Retired
MR2100-1TLAUS is an ISP / Telstra SKU. There is no option to manually update the firmware as it is locked by the Internet Provider. All upgrades are provided over-the-air.
Kindly describe the issue you are facing with your device. Can you please let us know what troubleshooting you've tried?
Blanca
Community Team
- TransfluxorOct 04, 2022ApprenticeThe router was bought on Aliexpress. The router does not boot (both with and without sim, with and without battery, tried with a third-party charger QC3.0 Xiaomi HA612). Two black dots on the screen and the power indicator blinks red. It doesn't show up in device manager. But if I hold down the reset at power on, the Netgear QDloader port appears. The Sierra / Netgear flasher may well flash, I only need the firmware to try, even the oldest one, and then update over the air.
- kopikoOct 12, 2022AspirantIt is actually not ISP locked. Intially I was using a Telstra Sim in it. Then I put in a Sim of a completely different carrier, A. The router was fine for 2 months and then the problems started. I couldn't save and changed settings. I cannot update. I tried factory resetting but it doesn't work. Wifi still worked so it was acceptable. I used it this way for about 3 months.
However I ended with carrier A and went to carrier B which uses the Telstra network. But now it is collecting dust as it just says "detecting service"- ArodiDOct 13, 2022NETGEAR Expert
Hi kopiko ,
"Detecting Service" on the LCD means that the device is unable to reach the Telstra data usage server. You will always see this message if you are using a non-Telstra SIM and some Telstra SIM's which are not supported by their data usage servers. The MR2100-1TLAUS is also configured with Telstra APN. If you use a non-Telstra SIM, you will need to create a new APN profile for your ISP and set it as the default profile. Tap Settings>Broadband>APN to setup a new APN profile.
ArodiD
- kopikoOct 16, 2022AspirantThe SIM is Boost which uses the Telstra network. When I try adding a new APN, nothing happens, which is my original problem of not being able to save any settings in the modem. Via web, "factory reset" and "power off" seems to be the only two things that the modem responds to. Except it doesn't really reset.
I checked the SIM APN when in a phone and it says telstra
