rychro
Jun 01, 2022Aspirant
Firmware Nighthakt M2
I have a bricked M2, it does not start. Please send me the current firmware. Best regards Roman
Blanca_O
Oct 03, 2022NETGEAR Employee Retired
MR2100-1TLAUS is an ISP / Telstra SKU. There is no option to manually update the firmware as it is locked by the Internet Provider. All upgrades are provided over-the-air.
Kindly describe the issue you are facing with your device. Can you please let us know what troubleshooting you've tried?
Blanca
Community Team
Transfluxor
Oct 04, 2022Apprentice
The router was bought on Aliexpress. The router does not boot (both with and without sim, with and without battery, tried with a third-party charger QC3.0 Xiaomi HA612). Two black dots on the screen and the power indicator blinks red. It doesn't show up in device manager. But if I hold down the reset at power on, the Netgear QDloader port appears. The Sierra / Netgear flasher may well flash, I only need the firmware to try, even the oldest one, and then update over the air.
