Wombo24
Aug 08, 2019Guide
Firmware update 1.0.0.44 Fails
An onscreen prompt appears advising "A router firmware upgrade is available". Attempting to update the firmware from Netgear server continually results in: "Downloading and updating the language...
- Sep 10, 2019
Hi, All,
Please try again the firmware update and let us know of the result. This should be fixed by now.
Blanca
Community Team
Ender76
Aug 31, 2019Initiate
I too am having this issue and have been for several months. Fails to install the language file from the new firmware 1.0.0.44_1.0.60 via auto update. I am unable to do a manual update as the Firmware for these smart cradles are nowhere to be found for download.
- Blanca_OSep 01, 2019NETGEAR Employee Retired
Hi, All,
This has been brought up already to engineers. I will get back to you guys for any updates.
Blanca
Community Team - Blanca_OSep 10, 2019NETGEAR Employee Retired
Hi, All,
Blanca
Community Team- Wombo24Sep 10, 2019Guide
Hello Blanca,
Yes the update worked successfully and I am now at V1.0.042_1.0.60
Thanks for your help getting that resolved.
Cheers,
John
- Blanca_OOct 08, 2019NETGEAR Employee Retired
Hi, All,
I have raised this issue several times to our engineering team. There are only few users who managed to get the firmware updated but majority are still having issue. And this is being investigated. We are now considering of posting the firmware on our support site. You may also send me a private message with the device SKU (DC112A-xxx) and I'll check with them if I can provide the firmware.
I apologize for the inconvenience this has all caused you and appreciate the patience.
Blanca
Community Team
Hi John,
Great! Thank you for the update. Glad that it's working now.
Blanca
Community Team - GraemeMcSep 10, 2019Aspirant
Still have a message saying “Firmware update available”, but when I check for updates it says “No update available”
Hardware Version
DC112A V1.0
Firmware Version
V1.0.0.42_1.0.60
GUI Language Version
V1.0.0.42_2.1.38.3
