tark
Feb 09, 2018Tutor
Firmware Update Error
Hi All i currnetly have Telstra Nighthawk M1 (MR1100) running EE sim in the UK. It currently has firmware NTG9X50C_10.12.02.01 which is old so when i click firmware update on the web page jus...
imsarsehus
Feb 11, 2018Star
try change apn setting
tark
Feb 11, 2018Tutor
not really much to change, the user name and password is correct, the APN name is correct and nothing else to use and the authenication is set to PAP.
either Netgear or somone along the line is blocking updates
- UK-basedFeb 11, 2018Luminary
It seems that the firmware and software GUI may be customised for the carrier/country. So when your M1 tries to update itself from the UK looking for Telstra-customised firmware, the host (whether that's Netgear or Telstra) may reject the attempted access from another country. This is just a guess.
- tarkFeb 11, 2018Tutor
i suspect if that is the case then perhaps a Telstra Sim in the UK i.e Roaming might work problem is actually getting one and having the SIM activated
