rightleft2
Nov 04, 2025Aspirant
Firmware update failing for LM1200
I get the message Firmware Update Failed, Invalid update file. The package is not supported when I use the firmware provided here. These are my hardware details:
Nov 05, 2025Guru - Experienced User
rightleft2 wrote:I get the message Firmware Update Failed, Invalid update file. The package is not supported when I use the firmware provided here
Which install are you using - Australia, US, or Europe?
Is it possible that you have the LM1200-111 model? Those installs are only for the LM1200-100.
