collier
Apr 29, 2017Aspirant
firmware update for ac782s
Why has firware update support for ac782s?
DarrenM
May 01, 2017Sr. NETGEAR Moderator
Hello collier
What issues are you having with the ac782
DarrenM
- collierMay 08, 2017Aspirant
Sorry, been out of contact. The ac782s used to check for updates and did so the last time I checked in Feb 2017 but since just reports 'update error - there was a problem updating your device - try again later'. A Telstra tech spent almost an hour trying to determine waht the problem was but could not. I assume the embedded URL in the device is no longer operable. Thanks
- DarrenMMay 10, 2017Sr. NETGEAR Moderator
Hello collier
If your device is still under warranty you might want to contact support.
http://www.netgear.com/support/contact.aspx
DarrenM
- collierMay 11, 2017Aspirant
It is 3 years old so I doubt if it is still under warranty. It was never registered.
