ronaldvr2132
Feb 06, 2017Apprentice
Firmware update voor Aircard AC790
Over time the connection of my iOS devices to my AC790 is getting worse where with the latest iOS 10.2.1 the WiFi connection is often dropped after which the AC790 is going into energy saving mode. F...
DarrenM
Feb 10, 2017Sr. NETGEAR Moderator
Hello Ronaldvr2132
In the wifi settings have you tried to change the 2.4Ghz bandwidth to 20mhz I have read from other community members that IOS devices do better on 20 compared to 40mhz.
DarrenM
ronaldvr2132
Feb 13, 2017Apprentice
Hello DarrenM,
Thanks for the advise.
I have adjusted it from 40Mhz to 20Mhz. I have not used the AC790 enough to verify if this solved the connection issues. Furthermore I noticed when adjusting the Mhz settings that on the 2.4Ghz WiFi band the password contained an additional a. Apparantly that changed unnoticed when putting the AC790 in a pocket a while ago. Hopefully with 20Mhz and the proper password the connections are stable again. Do you know if there is a new firmware in the make?
Thanks,
Ronald
