ronaldvr2132
Feb 06, 2017Apprentice
Firmware update voor Aircard AC790
Over time the connection of my iOS devices to my AC790 is getting worse where with the latest iOS 10.2.1 the WiFi connection is often dropped after which the AC790 is going into energy saving mode. F...
Erlbacher
Jun 20, 2017Aspirant
To your Info:
I have the same device with same Firmware 11.11.00.00
In May/June 2017 I was in Egypt and used the AC790 with a Orange SIM Card. It works fine.
After one Day of using, the AC790 shows a message, that there is a Firmware update with 73 MB for download.
I don't start it in Egypt, becaus when the update dosn't work properbly, I had no "plan B" far away from Home :-)
Back in Germany with a Vodafone SIM, I tried to start the Firmware update..... but I get only an error Message.
After 1-2 hour working with the AC 790, I get the same message on the AC 790 Display, that there is a new Firmware to install (manual Firmware update was not possible ???)
I start the download and the Installation on the AC 790 (connected with usb to my PC).
Now the Firmware is 11.11.15.00 - will try ist (WiFi in the car)
Hope it helps
Andreas
