Retired_Member
Feb 07, 2019Firmware update
Hello.
I am from Poland and I own the Nighthawk M1 AT & T branded router. Ruter has no sim lock and works in Poland. However, I have a problem. Router can not connect to the Arlo application. A...
microchip8
Feb 07, 2019Master
I don't know if this will work, but you may need to use TFTP to upload the newer firmware. This may help https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
- Retired_MemberFeb 07, 2019
Ok. Thank you for the suggestion. I will try to do this installation and let you know if it helped. Thank you very much for help.
Type in the command tftp -i [router IP] put [firmware filename].[file format]. Do NOT press Enter yet.
- Example: tftp -i 192.168.1.1 put R9000-V1.0.4.2.img
I work on a mac and I do not know where to insert this command
- microchip8Feb 07, 2019Master
you need to open a console and make sure you have the correct firmware image for your device model
I have a good firmware but with this link I can not cope with this procedure on a Mac. I have done the actions described in the link for Mac users one after the other, but from a certain moment the system returns to the Windows environment. That's why I asked where to put this command in os system? There is no such information in this link.
- matt-1Feb 18, 2019Aspirant
Hello.
File format from yours link (use TFTP to update firmware) should be img or chk. I receive new firmware file from netgear support to my router with format "spk". Can I use yours method or you can advice me something else.- antinodeFeb 18, 2019Guru
> procedure on a Mac. [...]"this procedure", as its title should suggest, is Windows-specific.
The Mac details can be found by following a link from:https://community.netgear.com/t5/x/x/m-p/1622096
> Model: MR1100|NIGHTHAWK M1What's wrong with this thing that makes you want to attack it with
TFTP? How does the normal firmware update fail? Visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual. Read. Look for "firmware".- matt-1Feb 18, 2019Aspirant
Router is from AT&T. In my settings there is no button (options) to firmware update and its say that my firmware is latest. I know that is no true. I want install the new one directly from netgear.
