Retired_Member
Feb 07, 2019Firmware update
Hello.
I am from Poland and I own the Nighthawk M1 AT & T branded router. Ruter has no sim lock and works in Poland. However, I have a problem. Router can not connect to the Arlo application. A...
microchip8
Feb 07, 2019Master
I don't know if this will work, but you may need to use TFTP to upload the newer firmware. This may help https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Retired_Member
Feb 07, 2019Ok. Thank you for the suggestion. I will try to do this installation and let you know if it helped. Thank you very much for help.
