Retired_Member
Feb 07, 2019Firmware update
Hello.
I am from Poland and I own the Nighthawk M1 AT & T branded router. Ruter has no sim lock and works in Poland. However, I have a problem. Router can not connect to the Arlo application. A...
microchip8
Feb 07, 2019Master
I don't know if this will work, but you may need to use TFTP to upload the newer firmware. This may help https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Retired_Member
Feb 07, 2019Type in the command tftp -i [router IP] put [firmware filename].[file format]. Do NOT press Enter yet.
- Example: tftp -i 192.168.1.1 put R9000-V1.0.4.2.img
I work on a mac and I do not know where to insert this command
- microchip8Feb 07, 2019Master
you need to open a console and make sure you have the correct firmware image for your device model
- Retired_MemberFeb 07, 2019
I have a good firmware but with this link I can not cope with this procedure on a Mac. I have done the actions described in the link for Mac users one after the other, but from a certain moment the system returns to the Windows environment. That's why I asked where to put this command in os system? There is no such information in this link.
what you mean? "Open the console"
Ok, I know what you mean...open a Terminal
