Retired_Member
Feb 07, 2019Firmware update
Hello.
I am from Poland and I own the Nighthawk M1 AT & T branded router. Ruter has no sim lock and works in Poland. However, I have a problem. Router can not connect to the Arlo application. A...
matt-1
Feb 18, 2019Aspirant
Hello.
File format from yours link (use TFTP to update firmware) should be img or chk. I receive new firmware file from netgear support to my router with format "spk". Can I use yours method or you can advice me something else.
antinode
Feb 18, 2019Guru
> I have a good firmware but with this link I can not cope with this
> procedure on a Mac. [...]
"this procedure", as its title should suggest, is Windows-specific.
The Mac details can be found by following a link from:
https://community.netgear.com/t5/x/x/m-p/1622096
> Model: MR1100|NIGHTHAWK M1
What's wrong with this thing that makes you want to attack it with
TFTP? How does the normal firmware update fail? Visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual. Read. Look for "firmware".
- matt-1Feb 18, 2019Aspirant
Router is from AT&T. In my settings there is no button (options) to firmware update and its say that my firmware is latest. I know that is no true. I want install the new one directly from netgear.
