FoxtrotAlpha
Dec 21, 2018Follower
Firmware upgrade on M1 Nighthawk (MR1100-1TLAUS)
Hello,
I have this M1 Nighthawk mobile router (more specifically, MR1100-1TLAUS).
Would appreciate if someone can enlighten me on the procedure to upgrade the firmware.
I did happen to come across...
Mexoh1To7k
Dec 23, 2018Apprentice
Hi,
Yes, early firmwares didn't have the option for manul update.
The update server is very irresponsive, but if you persist it will eventually work. It works even if you're not on Telstra's network.
