epicycler
Oct 19, 2016Aspirant
Firmware Version NTG9X40C_11.14.08.12
Aircard 810S (Telstra) intermittent problem after firmware update to version NTG9X40C_11.14.08.12 build date 2016/09/14.
Works for several hours then browser or ping unable to resolve host (no DNS).
Device status looks normal ie connected, 5 bars, RSRP -80dBa, ip address ok, etc.
Solution is turn device off/on - done through browser by changing upper limit of DHCP IP Range as I can't find "restart".
I haven't tried ping with a numerical ip address while problem exists.
Is anyone else having this problem? Is there a solution?
Is there a way back to previous firmware?
- DarrenMSr. NETGEAR Moderator
Hello epicycler
You would have to contact Telstra about this they may be able to get you a older firmware.
DarrenM
- epicyclerAspirant
thanks Darren,
guess what Telstra said before I posted here ......
I trust the issue has been forwarded to the appropriate Netgear department - if you don't tell them they won't know.
