SomebodyInGNV
Sep 19, 2022Guide
Flashing power light, LM1200
Does the power light on an LM1200 flash if there's no SIM? Mine worked fine with an AC adapter. I'm now trying to rig it up in my travel trailer using a 60W QC3.0-compatible USB-C power source runn...
- Sep 24, 2022
SomebodyInGNV wrote:
Does the power light on an LM1200 flash if there's no SIM?Try the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the sections in the manual Top Panel With Status LEDs and Troubleshoot With the LEDs.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
SomebodyInGNV
Sep 24, 2022Guide
Thanks. I resolved the problem when I got home by plugging in the SIM. It works. At that point I stopped looking further.
The "Troubleshoot with LEDs" section on p 100 of the manual you referenced specifically refers to the SIM being out.
michaelkenward
Sep 24, 2022Guru - Experienced User
That's good, which is why I suggested it.
