SkyJoe
Apr 22, 2021Follower
forgot Netgear Nighthawk MR1100 Genie password.
Hi. this is my first time asking a question. We have the Netgear Nighthawk MR1100 routermodem. we use the Android mobile app named Netgear Genie. I changed admin password when we got it. one day I we...
michaelkenward
Apr 24, 2021Guru - Experienced User
SkyJoe wrote:
I cant find where to reset Genie password so we can log into eouter.
The only way to recover from forgotten passwords is usually to get the device back to its factory settings and set the thing up from scratch.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Factory Reset Using the Reset Button.
You may have done that already. I can't tell from your message.
