Ram1986
Apr 23, 2019Aspirant
frimware update problem
please help me I cant update my frimware always searching for update but can't find anything ,I tried moblie app but the same, I download the update manually but invane! what it that problem?
Ram1986
Apr 24, 2019Aspirant
Mr1100 telstra
W1lliam
Apr 24, 2019Virtuoso
You can always download the firmware for Telstra model from here https://www.netgear.com/support/product/MR1100telstra.aspx
When I was on old firmware, can't remember which revision, it does not support manual upgrade, so you would need to try many times, on different days, to upgrade from the system.
William
- Ram1986Apr 24, 2019AspirantIt always searching but nothing found! Also the mobile app says that there is an error, it will search next 48 hours
- W1lliamApr 24, 2019Virtuoso
here is the link to the firmware itself, you need to do this upgrade from PC web browser, http://www.downloads.netgear.com/files/GDC/MR1100-1TLAUS/MR1100-1TLAUS_23113199_NTG9x50C_12.06.02.00_00_TELSTRA_04.04.secc.spk
William
- Ram1986Apr 24, 2019AspirantI downloaded the last update but can't setup it in the router
- Ram1986Apr 24, 2019AspirantVersion 10.12.02.01
