robatl
Sep 06, 2021Star
Gig ports speed reduced when access control is enabled.
Nighthawk LAX20 Firmware Version V1.1.6.28_2.0.49 Anyone else experiencing this issue or is my router defective?
robatl
Sep 15, 2021Star
I may have found the issue... I disabled the WMM feature under QOS and my speed on the gig ports normalized. I am getting my speeds with access control enabled.
- Blanca_OSep 20, 2021NETGEAR Employee Retired
Hi robatl
Thank you for update. We'll share this information to the product team.
Blanca
Community Team- robatlSep 24, 2021Star
I conducted a failover test to cell, since then my speed on the gig port has been back in the 300mbs to 400mbs. There are several scenarios that cause problems with the gig ports. I have rebooted and powered off the device several times. The speed gig speed would appear to working then it falls off.
