Spectrum1
Jan 06, 2023Tutor
Good Antenna Options for the Nighthawk M1?
Hi All
I purchased a pair of those cheap £13 Bingfu antennas as a test to see if I can get more than the 2bars 4G signal (Fair Signal), I’m getting from the internal antenna of the M1. The antennas are high up in the attic space of a two-story house.
Well, what a disappointment, these antennas are only able to provide a signal strength of 1bar (Poor Signal), worse than the internal M1 antenna!
Apart from buying expensive professional level antenna systems, are there any other less expensive antennas under £100 worth trying with the M1? E.g., the Netgear Omnidirectional MIMO Antenna?
Thanks all
- JohnPengNETGEAR Expert
Unfortunately, there are not many options available in the market considering the TS-9 connectors. You may have to use adaptors in order to connect to external antenna.
Thanks
Thanks John
What the ‘External’ antenna connectors on the M1 can and cannot do is a real minefield after reading the many very technical posts on this forum.
I must admit that when buying the M1 I was unaware of needing to have a PhD in cell tower systems in order to understand the M1 antenna connector specifications.
From what I have gathered so far:
- The M1 has 4 types of antennae installed internally
- The external antenna connectors only connect to 2 of these types
- The external antenna connectors are restricted in only supporting certain cellular bands
- There is a hack to drill holes into the M1 in order to create external antenna access to the other antennas inside the M1
- When you plug in an external antenna, the other internal antennas are switched off
- The Left antenna port is different from the Right port – Left is Primary, Right is secondary
For me, my needs are simple; I simply wish to try and increase the signal strength coming into the M1.
It would be so helpful if anyone here had a simple to explain and understand guide to the M1 External Antenna Connectors.
Checking the CellMapper app, I have two cell towers covering my house as shown below:
Cell Tower 1
Supported 4G Bands – 1, 20
Cell Area Covering my House: Frequency Band - IMT (B1 FDD)
Cell Tower 2
Supported 4G Bands - 1, 7, 8, 20
Cell Area Covering my House: Frequency Band - EU Digital Dividend (B20 FDD)
From the knowledge of the group, should an external antenna plugged into the M1 be able to work with the above cell tower bands?
Thanks
