ValiSan
Feb 23, 2023Aspirant
Google Remote Desktop
Hello, i have this MR1100 – Nighthawk M1 Mobile Router, and it worked fine for a while but lately i can't use Google Remote Desktop, any one can kindly please help me to fix it, thank you!
JohnPeng
Feb 23, 2023NETGEAR Expert
Please provide the SKU name and carrier you are using with the device.
Thanks
John
ValiSan
AT&T carrier, as for SKU not sure where to look for it :-SS
- JohnPengFeb 23, 2023NETGEAR Expert
The SKU name is printed on the device label under the battery.
Thanks
John
- ValiSanFeb 23, 2023Aspirant
MR1100-100NAS
This is most likely due to carrier subscription.
Could you please try wifi offloding or ethernet offloading to your home network and see whether the issue can be reproduced?
Thanks
John
- ValiSanFeb 27, 2023Aspirant
forgive me Sir, but i don't understand quite well what should i do, i use that remotely to connect home
