LD2012
Aug 30, 2021Aspirant
@Help- Wifi chewing up data
Hi, can anyone help? We're using the Nighthawk M2 and it's using up way too much data too quickly. 36GB used in 5 days with minimal office type use with 2 computers and 1 mobile using wifi whilst wo...
LD2012
Thanks plemans,
Is there anything we can do to reduce the data the TV uses? Is there a different setup?
Cheers
Cheers
Aug 31, 2021Guru - Experienced User
https://help.netflix.com/en/node/87
here's netflix's FAQ on reducing data usage.
