barrelgurl08
Feb 01, 2022Aspirant
HELP!! LM1200
I live in a very rural area where no wifi is avaliable accept sat internet and it was worthless. I bought a LM1200 and Linksys. It worked on a Straight talk unlimited plan for a year or more. Now th...
JohnPeng
Feb 13, 2022NETGEAR Expert
Please check with your carrier why the service is not avaliable anymore if doing a factory reset can't fix the issue.
You can also do a manual network scan to see which carriers' networks are available at your location. Then check whether you can get a new plan from the available carriers.
Thanks
