smkyballs
Jan 29, 2025Aspirant
help Netgear air card 77s1 need to activate
hello I have a net gear air card 771s how to I go about getting it activated today what steps can I take
smkyballs
thank you for the reply but I'm having a hard time figuring this out I have no idea on what to do
JBish
What carrier? Location? Branded device or Unlocked?
- smkyballsJan 29, 2025AspirantIt's a Netgear 771s sprint it's unlocked. T mobile is giving me such a problem I can't do it through them I just need a direction
- JBishJan 29, 2025Aspirant
You will need to activate through the carrier, no work arounds for that
- rcpaxJan 29, 2025Luminary
smkyballs wrote:
It's a Netgear 771s sprint it's unlocked. T mobile is giving me such a problem I can't do it through them I just need a directionwhat specific problem are you having with it? give us specifics so we know what's going on. If it's truly an unlocked device, once you put the SIM in, it should pick up a signal and connect. What errors have you encountered. T-Mobile, to me, is the least restrictive carrier of all the big three. give us the steps you have taken so far and where are you stuck at.
Here is the User Guide you can DL and use to help you troubleshoot, if you require it: https://www.downloads.netgear.com/files/aircard/4114045%20Sprint%20AC771S%20UG%20r2.pdf
- JBishJan 30, 2025Aspirant
If it is an unlocked device, it may not have the correct apns. Put the sim in a phone and register it on the network. Pop it out and try in the device
