Joenemba
Jun 17, 2024Guide
HELP requested: Mobile Broadband Disconnecting
I've been using an MR6110 I got from AT&T for about a month now. Hadn't really had any issues until around 11:00 pm on June 16th. I was spammed with Confirm APN settings (Error 1028) on my device and...
Blanca_O
Jun 24, 2024NETGEAR Employee Retired
Hi Joenemba,
How many devices are connected when you see the error code?
Do you have the device powered on with or without the battery?
Have you tried running the device without a battery while using bandwidth heavy applications?
Please check the KB link below to confirm the APN Settings:
https://kb.netgear.com/000065793/Mobile-Hotspot-APN-Lookup
Blanca
Community Team
- JoenembaJun 28, 2024GuideHi, Blanca
Apologies for my delay in response, the weirdest thing is it basically started working fine this entire past week, before it started cutting out this night.
I checked APN settings, at maximum around 4 devices connect to it, and we always run it plugged in without battery. I've been to two different AT&T stores, I've replaced the SIM Card, and it still didn't fix it, but then Monday of this week it randomly started working again? And now it's stopped. Literally no clue why.
Is it possible that I'm like, kicked off the Network by AT&T? Like my priority is low or something? Sometimes it will say that I'm connected, but not to AT&Ts Network, and say I'm on T-Mobile or Verizon.
