Racy
Aug 05, 2019Tutor
Hide Nighthawk M2 model wi-fi username and password
I can’t hide the Netgear Nighthawk Wi-Fi username and password. I also have the M1 model, and to hide those details it’s a simple tick box that stops the details being displayed on the LCD. If I sele...
Blanca_O
Aug 11, 2019NETGEAR Employee Retired
Hi Racy
Welcome to NETGEAR Community!
I would like to get more details of your device.
What is the exact model number of your device?
What is the firmware version?
Blanca
Community Team
Racy
Aug 12, 2019Tutor
Hi,
Thanks for your reply.
The Model No is MR2100
The SKU reference from the box is MR2100-1EEEUS
Teh Firmware Version is NTGX24_10.13.09.00
- W1lliamSep 04, 2019Virtuoso
With FW NTGX24_10.13.09.00, you can disable displaying the detail on LCD by SETTINGS->Setup->Wireless and uncheck "Display info on LCD", then you won't see the detail on LCD. This is done from Web GUI, not on the LCD itself.
- RacySep 05, 2019Tutor
I agree the option is there, it was through the Web GUI I unticked “Display info on LCD”, but it does not remove the detail on the LCD, it only masks the username and password (which can be unmasked simply by tapping them) as per my original post.
I have an M1 on the unticking the box works perfectly, but the M2, in my opinion, has a serious security flaw.
- W1lliamSep 06, 2019Virtuoso
Yes, you are right about LCD info which can be retrived easily by tapping the screen, even disable it from Web GUI. This would need to have Netgear to fix it.
