tiffanieee56
Feb 17, 2023Aspirant
Hiding my network (SSID) Nighthawk M6 model MR6110
I am interested in hiding my network from others. But if that can be done how do I access it? I have been all over the admin site and havent been able to find it......definitely a newby...thanks for...
Blanca_O
Feb 22, 2023NETGEAR Employee Retired
Hi tiffanieee56
Welcome to NETGEAR Community!
1. From a computer or WiFi device that is connected to the Nighthawk M6, launch a web browser.
2. Enter http://192.168.1.1.
The Nighthawk M6 web page displays.
3. Enter the administrator login password.
The default password is printed on the product label. The password is case sensitive.
4. Go to Settings > General > WiFi Band > Uncheck "Broadcast WiFi Name SSID"
- If you wish to hide the Wireless Information on the M6 LCD, uncheck "Display info on LCD"
5. Click Apply
Blanca
Community Team
tiffanieee56
Feb 23, 2023Aspirant
Hi....wow I found you ...just wanted to thank you for your help...I realize now I should have told you that I know how to get into the admin site....sorry bout that and I have already asked this question on the forum but as a followup question ...how would I now sign into my wifi SSID now that it is hidden....do you go to "other networks and put it in manually? Thanks in advance...
- Blanca_OFeb 23, 2023NETGEAR Employee Retired
Hi tiffanieee56
You would have to manually connect to the network by entering the Network Name, Security Type and Password.
You may check this KB article: https://kb.netgear.com/30740/How-do-I-connect-to-a-hidden-network
Blanca
Community Team
