Docflop
Mar 05, 2022Follower
High RSRQ on MR1100
I am having terribly high RSRQ only getting like 2 to 3 MB/s the RSRQ stays at -16dBm which is not good I have talked to at&t about it but they told me to reset the box I have done it twice and nothing has helped would a signal booster work? This has been going on for over like a month but before then I had perfect speeds never had a problem. I just got this box yesterday because I thought my old one was bad but this is doing the same thing.
Firmware version- NTG9X50C_12.05.05.14
Bootloader is the same
Firmware build date was 2020
PRI version-04.06
1 Reply
- JohnPengNETGEAR Expert
The FW version on your device is quite old. Please try upgrade to the latest release if you can.
Thanks
