wagwarnas
Jan 12, 2021Aspirant
Home WiFi Router Recommendation
Can anyone recommend a good home wifi router that supports USB hotspot tethering? I have a Verizon hotspot for internet access and no cable ISP. and I want to tether it to a router to keep it charge...
michaelkenward
Jan 13, 2021Guru - Experienced User
While you wait for informed answers, how about checking the proiduct pages?
Mobile Wifi Hotspots - Mobile Wifi Routers | NETGEAR
You can then dig out the manuals and data sheets for anything that takes your fancy.
- wagwarnasJan 13, 2021Aspirant
thanks, good idea! I did and I don't see one that supports Verizon.
- michaelkenwardJan 13, 2021Guru - Experienced User
Routers don't "support" any particular ISP. They work with whatever modem or "termination" connects you to the Internet. Ignore Verizon
