smokeyforester's avatar
Jul 08, 2016
How can I convert WiFi to Ethernet?
I need to convert WiFi signal to Ethernet.  What device do I need to so that?
I will be using a Netgear 779S Fuse Mobile Hotspot which receives Sprint data and broadcasts WiFi.  I want to receive that WiFi signal and convert it to Ethernet.  Please advise what device will do that.
  • smokeyforester's avatar
    smokeyforester
    Jul 16, 2016
    EX6100 can receive WiFi and output Ethernet.  There's a speed cost of about a third, but since I'm starting with such a fast (Netgear 699 Hotspot) connection, I can afford to lose some speed.  So that's the answer.
No RepliesBe the first to reply
