Muffler121's avatar
Muffler121
How do i connect alexa 4th gen to netgear m1
  • What do the instructions for the "alexa 4th gen" say?
    As a router, the M1 (MR1100?) just delivers the Internet. If you need to make any changes to the WiFi on the router, the Alexa thing should tell you where to look.
    Usually it is just a case of following the instructions from Alexa.
  • Hi thanks for the reply its says i have to pit netgear in share anywhare but i cant find it on the uk app
    • michaelkenward's avatar
      michaelkenward
      Guru
      Muffler121 wrote:
      ... its says i have to pit netgear in share anywhare but i cant find it on the uk app
      I have no idea what "share anywhare" means.
      What is the exact wording of the instructions?
