waynek0650
Dec 10, 2020Aspirant
how do I connect my mr1100 to spectrum cable modem
Dec 11, 2020Guru - Experienced User
Netgear does have dual wan routers but they tend to be business grade devices.
make them more expensive if purchased new. I've seen people snag them used of ebay for fairly reasonable as corporations upgrade. Like the FVS336G
Other options are EdgeRouter has some dual wan capable routers that are pretty solid.
waynek0650
Dec 11, 2020Aspirant
Thank you, I will look into each of these. I appreciate the suggestions.
