egberts's avatar
egberts
Guide
Oct 15, 2016
How do I install drivers on macOS (Sierra) for AC340U?
New driver came out today!  And for the macOS Sierra (we don't call it Mac OSX anymore).
http://kb.netgear.com/app/answers/detail/a_id/26983/(Opens%20in%20new%20window)~/aircard-340u-(at%26t-beam)-downloads-and-documentation?cid=wmt_netgear_organic
Since I've upgrade (and later fresh-installed) macOS on my Macbook Pro, the AT&T NetBeam/NetGear AirCard 340U has been rendered disabled.  Recognized by the macOS, yes, at USB-level.  But the drivers refuse to interact with it.
With this NEW driver, I downloaded it.  I'm puzzled.  It is a zip file.  With a 'Contents' folder.  And a 'Resources' folder inside that.
What is the installation procedure for incorporating this latest and greatest driver into macOS?
  • I am typing this using the latest Drivers_10.9.pkg found inside the downloaded ZIP file in macOS Sierra (aka Mac OSX 10.12).
    Double click it that Drivers_10.9.pkg.  Once installed and rebooted, AirCard Watcher app should also start after re-login.
    From there, I clicked 'connect' inside the AirCard Watcher app.  Wow...  this is so sweet.
    Life is good.
    Life is good.
    • Same here!  The installation of the new drivers for Sierra was succesful and now my AirCard works once again.
      Thanks to whomever was responsible for the new driver!!!
      -Archie
