UsaTraveler1
Apr 17, 2021Aspirant
How do I log into my nighthawk Mr1100 when it’s in pass through mode
HELP! I have a MR1100 hotspot. I connected a Linksys Velop router through the Ethernet port and set the router to pass through. When I did this it shuts the WiFi of on the nighthawk. Now I can't log ...
UsaTraveler1
Update, I'm able to log into the hotspot now. Still the only problem I have is that it will drop internet connection for no reason and I'm thinking it has to do with the Linksys Velop Node. Still looking for someone that has used this setup successfully that could walk me through the set up. I'm thinking that I just don't have everything configured the way it should be.
michaelkenward
Apr 18, 2021Guru - Experienced User
UsaTraveler1 wrote:
....I'm thinking it has to do with the Linksys Velop Node.
Doesn't sound like this has uch to do with Netgear. Tried it on the people at Linksys?
You probably won't find much help with that in this section of the Netgear community.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are a bit more specialist than routers and may need a real expert to chip in.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
