UsaTraveler1
Apr 17, 2021Aspirant
How do I log into my nighthawk Mr1100 when it’s in pass through mode
HELP! I have a MR1100 hotspot. I connected a Linksys Velop router through the Ethernet port and set the router to pass through. When I did this it shuts the WiFi of on the nighthawk. Now I can't log ...
UsaTraveler1
Update, I'm able to log into the hotspot now. Still the only problem I have is that it will drop internet connection for no reason and I'm thinking it has to do with the Linksys Velop Node. Still looking for someone that has used this setup successfully that could walk me through the set up. I'm thinking that I just don't have everything configured the way it should be.
UsaTraveler1
Apr 25, 2021Aspirant
I bought AC2300 and it works with the MR1100 hotspot great. The hotspot will still reboot randomly. I have noticed that it seems to happen more when the cell tower that it gets its signal from gets congested. AT&T and Netgear both know about the issue. It's been discussed on this forum for years with no fix. AT&T and Netgear just blame each other but do nothing to fix the issue!
