Sistermoon
Jul 25, 2021Aspirant
How do i manually update the firmware on Nighhawk m1 ( mr1100)?
Hello and thanks for helping When i click on "check for updates" in administration manu on router's login page. it says it's uptodate! . while when i check the version and date and compare it with ...
antinode
Jul 25, 2021Guru
> I noticed Netgear lets me downlaod the firmware from the site. but
> there is no way for me to upload it into the device..
"there is no way"? Interesting conclusion. Any basis?
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
Sistermoon
Hi and thankd for your reply...
by not being able to upload teh firmware manually i mean theres no field for me to upload the firmware into device. i will take screenshots if it helps...
Thank you for your time
