Sistermoon
Jul 25, 2021Aspirant
How do i manually update the firmware on Nighhawk m1 ( mr1100)?
Hello and thanks for helping When i click on "check for updates" in administration manu on router's login page. it says it's uptodate! . while when i check the version and date and compare it with ...
michaelkenward
Jul 26, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but mobile routers and hotspots differ from standard routers in many ways, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Sistermoon
Jul 26, 2021Aspirant
Thanks for moving my thread to correct section. ALso if anyway know of a way how to TFTP into MR1100 it would help me and mny others.
- michaelkenwardJul 26, 2021Guru - Experienced User
- SistermoonJul 26, 2021Aspirant
Ofcourse. First thing i did. only one topic has same question and at the end he asks if anyone tried to TFTP and no one answered.
- FeeldennisJul 31, 2021Tutor
Check out this link, I just updated mine this way.
