RichValley
May 12, 2022Aspirant
How do I rollback the firmware version on R7000
How do I rollback the firmware version on R7000? In Device Manager, not all connected devices are appearing, and I understand from other posts that the latest firmware version is the cause of the problem. How do I rollback to a previous version?
1 Reply
You download the version you want from the support site.
Then simply follow the manual update process (from the manual) but use the version you downloaded.
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
