SomebodySysop's avatar
Aug 25, 2022
How to access LM1200 on Network
I have Netgear LTE Modem LM1200.    Firmware Version: EC25AFFDR07A09M4G Firmware Build Date: Unknown App Version: NTG9X07C_20.06.09.00 Web App Version: LM1200-HDATA_03.03.103.201   If I plug i...
  • SomebodySysop's avatar
    Aug 27, 2022
    Solved the problem.  I had to go into advanced settings -> lan: Select "router" mode, then turn off dhcp, then change ip (192.168.1.253 in my case), then switch to "bridge" mode, then save. A lot of hoops for sure, but when I did this and plugged lm1200 into my 192.168.1.0/24 network, I was able to reach the dashboard on the network.
