deanoky's avatar
deanoky
Follower
Apr 11, 2019
How to change my email address for notifications
How do I change the email address netgear has on file for me so I can still get update notices.
  • Afflospark's avatar
    Apr 12, 2019
    Hello,
    You can change your email address for notification via login your Netgear community account https://my.netgear.com  with your login credentials. In that account, you can click on the profile option and then click on update your email address.
    Hope this will help you to update your email.
    Afflospark
