Speedtriple
Dec 23, 2019Aspirant
How to connect external antenna to AirCard 800s
Im using an AirCard 800S on a boat with an Omni directional marine antenna and was wondering which TS9 port I should be connecting to? The AirCard has two ports for a MIMO antenna however the mar...
Blanca_O
Dec 26, 2019NETGEAR Employee Retired
Hi Speedtriple
Welcome to NETGEAR Community!
To connect an external antenna to the NETGEAR AirCard USB modem/mobile hotspot, an antenna with a single or dual SMK TS-9 male connectors (or antenna with a single or dual SMK TS-9 male adapters) is required.
https://kb.netgear.com/23901/External-Antennas-for-AirCard-products
Blanca
Community Team
Speedtriple
Dec 27, 2019Aspirant
Thanks Bianca, if I have an antenna with a single TS-9 connector what port do I plug into? The Aircard has two to choose from.
