150mph
Jan 12, 2023Aspirant
How to connect Nighthawk MR6110 wifi hotspot using ethernet, instead of wifi?
Because I was told a direct ethernet connection will be the fastest possible connection I'll get from this hotspot, equal to or greater than wifi - and just plugging in the ethernet cable doesn't do...
Kitsap
Jan 12, 2023Master
150mph wrote:Thats my first post, and the section was "Nighthawk with WiFi...." which is exactly the device/hardware I'm inquiring about.
I'll take your word that a forum called "/t5/Cell-Service-Mobile-Hotspot/bd-p/aircard" would be more appropriate, but it would be better if a mod moved it, rather than have 2 identical posts.
Whats your suggestion on how to proceed?
A moderator has moved your post. Good luck.
150mph
Jan 21, 2023Aspirant
THanks for moving my post. To a place where no one knows or will help.
