MichaelsB
Aug 19, 2023Aspirant
How to disable AP Isolation
 Please help with this
Kitsap
Aug 19, 2023Master
If you want detailed help, you have to answer the question. What is the specific model number of the device you need help with? Look on the name plate on the back for the model number.
- michaelkenwardAug 19, 2023Guru - Experienced User
MichaelsB wrote:
Kitsap The model of the router is M6 Pro MR6500That is not one of the Nighthawk Wi-Fi 5 (AC) Routers covered by people who watch this section.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.- MichaelsBAug 19, 2023AspirantI’ve been trying to connect my chromecast to the above mentioned netgear nighthawk m6 pro router. Has anyone been successful in connecting their chromecast to the netgear router? Please help.
