EliMadden
May 05, 2018Initiate
How to disable auto-power-on when Nighthawk M1 is connected to USB
My Nighthawk M1 automatically turns on when I connect it to a USB port that's active. This is a problem in my vehicle because sometimes I don't want it on, but the power goes off and on with the igni...
EliMadden
May 08, 2018Initiate
I don't want to turn off the USB port. I just want the Nighthawk to NOT turn itself on when the USB port is connected to power after not being connected to power.
This is not only a problem in my car, but also when I bring it in and connect it to a charger I don't want it to turn itself on, I just want it to charge.
Basically, just don't have the device turn itself on. I want to control it with the power button.
JasonN
May 15, 2018NETGEAR Employee Retired
Hi EliMadden & KarmusDK,
Thank you for your suggestion. I will forward this idea to my internal team for review of consideration. :]
- Jason N
