mhaynes1970's avatar
mhaynes1970
Follower
Mar 26, 2023
how to disable sip ald night hawk m1
H does anyone know how I could turn off the SIP ALD and then enable/turn on QoS on the model router of a nighthawk m1.
Thank you.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
