yalcinc's avatar
yalcinc
Follower
May 25, 2021
How to disable speed negotiation on 5G WiFi 6 Mobile Router (MR5200) ?
For a very specific application, I need to set ethernet speed on wired connection (RJ45 jack) manually, disabling the auto-negotiation.
I am hoping to be able to set speed to, say, 100Mbps or 1Gbps manually as needed.
Is this possible? How do I do that?
  • Hi yalcinc
    Welcome to NETGEAR Community!
    There is no option on the MR5200 setting to disable speed negotiation.
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi yalcinc
    Blanca
    Community Team
